Set Fail Safe
Description
This tool enables the Fail Safe Boot Feature and can be bought from Toradex (contact colibri@toradex.com). The tool only needs to be executed once in order to enable or disable the Fail Safe Boot Feature.
With this tool you can
Set Fail Safe Help
Command Line Parameters
Example: SetFailSafe.exe
 /d
Example: SetFailSafe.exe /d
  • unattended mode (this will generate no output at all)
/u
Example: SetFailSafe.exe /u
  • Print a help function on the command line
/h
Example: SetFailSafe.exe /h
Return Values
When you start the SetFailSafe Tool via command line, you can check the return value to verify if the Update was successful. -1 :error 0 :successful
Combinations
All commands can be combined, though some don't make much sense.
Restrictions
This tool only works with Bootloader 3.6 Beta 1 or later
